08-07-2005 08:28 AM - edited 03-15-2019 03:38 AM
I have a customer that use to have a very dated panasonic system. We have replaced it with CCME and everything is working fine except they used the speaker phone alot with the old system. Now they are complaining that the new phones volume is to low. they have it turned up all of the way and they did save the setting in the phone but they still say it is to soft. Is there any way to adjust this. It is not outside calls but IP phone to IP phone volume that is to low. Thanks alot for your help.
08-11-2005 12:06 PM
Yes you can change the volume using the button shown the picture.
08-11-2005 12:29 PM
Which IOS version (for your CCME) and phone load do you have?
Also take a look at bug CSCuk52433. I know you are not using CallManager, but this is a phone load bug. So, it applies to CallManager Express as well.
Srikanth
