Answering other phones from CUEAC console
Joe Bohelski
Does anyone know if it's possible to answer other ringing phones from the CUEAC console?  Our receptionist can see the phones are ringing, but when she right clicks on one, the Answer option is greyed out.  I don't know that it can be done, but thought I'd ask the community.  It doesn't seem to make a difference that the lines are in the same call pickup group.
Jaime Valencia
I don't think this is possible, because the ones that are controlling the call are the CTI port and CTI RPs, if the phone is in the same pickup group as the ones ringing, she can just use the pickup softkey on the phone directly.
java
if this helps, please rate
Jaime Valencia
java
That's what I thought too, but wanted to make sure.  Thanks for confirming, Jaime.
