AS5300, I NEED HELP
w.zhanghua
HI,
as5300 can support 120 voices(4E1),look this diagram
120 phones----(RJ11)PBX---?--AS5300---ROUTER------
What kinds of the connectivity between the PBX and AS5300, E&M with RJ45? or others?
another question is :does the as5300 can directly connect the 120 phones?
the 3rd question is : the AS5300 has 4E1,so the 4E1
connect the PBX? if so can you tell me the connectivity ,RJ45?
THANK YOU
vassatrian
1. The connectivity between the PABX and router has to be digital: E1 as minimum.
2. AS5300 does not support any directly connected phones.
AS5300 does not support the following interfaces: FXO/FXS/E&M.
Look, can you guarantee that all 120 extensions will make calls simultaneously?
Instead of connecting 4E1 to AS5300 I will recommend you to deploy some sort of proportion between the number of extensions and tie-lines: in telephony world we used to use (3-7) to (1), but it is very customer specific.
Based on my experience for 120 extensions I would use 1 or maximum 3 E1s, once again very customer dependant proportion.
3. Yes, this is 4 E1 connected to PABX and the connectivity will be:
Physical – RJ45, signalling and other settings – follow up your country specification.
