07-19-2005 08:03 AM - edited 03-13-2019 09:51 AM
Hi.
There are good feature in ata-186 -
distinctive ring, so internal calls generate one ring, externals two short rings.
But many customers migrate from old pbx, wich rings totally different (in default configuration).
How I can configure this distinctive ring ?
Maybe this is not implemeted yet? I think this is trivial modification - only one bit in config file can be used.
07-25-2005 06:28 AM
The Cisco ATA provides a distinction in the ringer sound for internal and external calls. Internal calls generate one ring, while external calls generate two rings with a very short pause between the rings. No configuration is required and the ring patterns are not configurable.
Go to service parameters -->call manager --> and set the parameter "H323 Network Location OffNet" to true.
07-25-2005 07:49 AM
Great idea, but useless for our customers.
We use mgcp gateways and incoming calls already marked as external(OffNet).
It seems cisco don't offer imperceptible migration. It is sad.
