ATA 186 Polarity Reversal Issue
praneet
I want to activate my billing machine which is connected through ATA 186 Box. I understand, to do that I need to reverse polarity. How to Reverse Polarity in this ATA 186 and what will be the parameters in the following fields :
1. CallerIdMethod : ?
2. Polarity : ? (If only Callee_connect & Callee_disconnect bits are masked)
Secondly How should I proceed with masking the bits.
beth-martin
Level 5
Level 5
Hello:
Check bit 11 in the following profile excerpt, good place to start :# else {# bit 3-6 (mask 0x78): start digit (12)# bit 7-10 (mask 0x780): end digit (14)# bit 11 (mask 0x800): polarity reversal (1)# bit 12-16 (mask 0x1f000): max no. of digits (15)# }
