06-30-2004 02:20 PM - edited 03-13-2019 05:29 AM
Can anyone give me a tip about using the "forward on busy" feature on ATA with h.323? I tried dialing #74<number># but with no luck. I'm using firmware 3.1 for h.323 with a h.323 gatekeeper on the lab.
07-06-2004 01:00 PM
Unfortunately, the supplementary service of call forwarding is not available to H323 terminals such as the H323 ATA and the gatekeeper is not capable of performing call forwarding on behalf of its registered H323 terminals.
Call fowarding is only achievable in the presence of call agents such as the Cisco CallManager or
SIP proxy server
07-06-2004 01:52 PM
Thanks for your answer ebreniz. I already found the way to use call forwarding with SIP and without a proxy server. Using a SIP image (I use 3.1) just dial #74
I'm using four ATAs configured in pairs, so that one ATA is configured as the Proxy of the other in the pair. I also combined call forwarding with the hotline feature, so I don't have to dial anything to establish a conversation with the other party.
A usefull thing to connect the ATAs as PBX's lines!
Good luck,
cabral_leonardo [at] yahoo.com.ar
