01-14-2006
12:10 PM
- last edited on
03-25-2019
06:50 PM
by
ciscomoderator
I have problem with my ATAs not registering with Call manager. When I monitored the traffic between them, the ATAs do get the loadfiles from the CCM via TFTP but the ATA requests for xxx.cnf.xml file via tftp from the CCM and the CCM responds with a file not found error. Pls can someone assist?
01-14-2006 03:26 PM
I suspect that you do not have auto-registration enabled and that you have not configured the ata manually because the file is not found. Please follow the instructions for Adding Cisco ATAs Manually
01-15-2006 07:23 AM
Hinho,
Thanks for your response but I've gone through this doc before now and followed each step without success. I'm sure it's something else thats beyond auto registeration.
01-16-2006 06:49 AM
Try to look about the version of ATA because some version like 2.11 doesnt work and you have to update to the last
01-18-2006 02:44 PM
I had an issue like this where that ATA would register, but I would get errors in the event log still related to this device. I had to disable the 2nd phone port by setting the SID1 or EPID1 parameter to 0. It turns out there are two configuration files for an ATA one for the 1st port and a separate file for port number 2. The ATA will send requests for both.
