Building VoIP solution.
johnleeee
Hi all,
I deeply apreciate help about configuring VoIP.
We have customer which wants implement VoIP or
clear IP telephony.
Customer has own PBX on which analog and digital phones are hanged in one locality.Locality mean one country. Second locality has own PBX too. This locality is another country. And they want to decrese expensies on international calls so they decided to migrate to VoIP or IP telephony.
My question is how I need to populate their Cisco 3620 on one side and 2610XM on other side
to function properly and connect these to PBX on both sides.? Which network cards I should use to connect routers to PBX.? Should I populate routers with DSP modules ? Could I connect PBX with router through PRI port ,if yes which module should I use.?
So, my question is long but I need deep help because Im not very familiar with connfiguring VoIP and which modules are better than other and which I can instal to meet requirements of customer.
thanks all for advice
rg
jl
sbilgi
Level 5
Level 5
