CCME and CCM Intercluster trunk?
jamesowen
Anyone have any idea how an intercluster trunk can be setup between CCME (3.0) and a CCM cluster? I know I can use a gatekeeper to route calls between the two, but I'm trying to figure out if it can be done without a gatekeeper.
pbarman
Level 5
Level 5
ICT is not supported with CME 3.0, but is supported on CME 3.1. The link below explains how to configure ICT in CME 3.1
http://www.cisco.com/univercd/cc/td/doc/product/software/ios123/123newft/123t/123t_7/cme31sa/cme31bsc.htm#wp1001000
If you have CME 3.0, on the CCM add the CME router as a H323 gateway. Use route pattern to route calls to CME. On CME use voip dial-peers to send calls to CCM.
Hope this helps!
Partha
