CDR Date problem
luzhenning
Hi all:
I have encounted a CDR Date problem.There are 2 CCM 4.0.2,one PUB,one SUB,all IP Phone register to SUB.One day,customer told me that when he used CDR,the CDR only can have record from 27/10/2004 to 27/03/2005.So I purge old file to 23/04/2005,and change to max CDR record,restart the PUB,all is OK,the CDR begin to record.
But customer told me that the CDR only can report data from 23/04/2005 to 25/04/2005.It is very strange.and I find that the C:\program files\Cisco\CDR has lots of file,so I change the inter insert time from 1 Min to 60 Min.and there is no file on that folder.But the report can only report that range.
So can anybody reslove the problem?thanks
irisrios
Level 6
Level 6
Perform these steps to determine if you have any record in the Structured Query Language (SQL) database:
Select Start > Programs > SQL > Enterprise Manager > Microsoft SQL Servers > SQL Server Group .
Select Publisher Server > Databases.
Select CDR > Tables. Right click on the CallDetailRecord table.
Select Open Table > Return All Rows. Determine if there are any records.
If you see many records, perform this procedure to remove records from ART:
Go to Programs > SQL Server > Query Analyzer. Log in and select ART database.
Run these queries:
delete from Tbl_Load_History
delete from Tbl_Dump_PkID
delete from Tbl_Error_Id_Map
delete from Tbl_Billing_Data
delete from Tbl_Billing_Error
delete from Tbl_Dump_CallDetailRecord
delete from Tbl_Dump_CallDetailRecordDiagnostic
This forces ART to get all the old CDRs into ART during the next scheduled loading time. By default, CDR data is loaded every day from midnight to 5 a.m.
