CME - max phone limit 72 or 96 ?
thisisshanky
Level 11
Level 11
The documentation is clearly misleading.
One document says, 2851 can support upto 72 phones on CME, while another says 96. Which one is the right info ?
http://www.cisco.com/en/US/products/ps5882/index.html --- shows as 72.
http://www.cisco.com/en/US/products/sw/voicesw/ps4625/prod_release_note09186a008055677f.html ----- shows as 96.
Sankar Nair
UC Solutions Architect
Pacific Northwest | CDW
CCIE Collaboration #17135 Emeritus
r.humphries
"This solution is for customers with data-connectivity requirements interested in deploying a converged IP telephony solution for up to 72 IP phones and-as of Cisco IOS 12.3(11) release-for up to 96 IP phones."
http://www.cisco.com/en/US/products/ps5854/products_data_sheet0900aecd8016fa68.html
r.humphries
Interesting. I get 76 in the CLI on my 2851 running 12-3(8)T8.
AU2851PTP#sh ver
Cisco IOS Software, 2800 Software (C2800NM-SPSERVICESK9-M), Version 12.3(8)T8, R
ELEASE SOFTWARE (fc1)
Copyright (c) 1986-2005 by Cisco Systems, Inc.
Compiled Wed 06-Apr-05 16:46 by yiyan
ROM: System Bootstrap, Version 12.3(8r)T7, RELEASE SOFTWARE (fc1)
AU2851PTP uptime is 18 weeks, 15 hours, 27 minutes
System restarted at 20:42:03 CDT Thu Jun 30 2005
System image file is "flash:c2800nm-spservicesk9-mz.123-8.T8.bin"
A summary of U.S. laws governing Cisco cryptographic products may be found at:
export@cisco.com.
Cisco 2851 (revision 53.51) with 251904K/10240K bytes of memory.
Processor board ID FTX0919A0SL
2 Gigabit Ethernet interfaces
25 Serial interfaces
1 Channelized T1/PRI port
4 Voice FXO interfaces
4 Voice FXS interfaces
DRAM configuration is 64 bits wide with parity enabled.
239K bytes of non-volatile configuration memory.
125184K bytes of ATA CompactFlash (Read/Write)
AU2851PTP#
AU2851PTP#config t
AU2851PTP(config)#telephony-service
AU2851PTP(config-telephony)#max-ephone ?
<1-76> Maximum phones to support
Michael,
Seems like, the software programmer mixed up 72 and 96 to 76 ? LOL.
Sankar Nair
Yeah, I guess they should've asked the forum before coding... LOL
