CME speed dial setup for 7912 stations
sangsounlee
It does not look like speeddial.xml is recognized by 7912.
Does anyone know how to enable speed dial for the 7912 model in CallManager Express ?
sbilgi
Level 5
Level 5
Program Personal Speed-Dial Buttons
Once an administrator has defined one or more speed-dial instances for a Cisco Unified IP phone, you can reprogram numbers that are not locked or can program numbers into an instance that has an empty dial string by following these steps:
Step 1 Select an available phone line by lifting the handset, by pressing the NewCall soft key, or by pressing a button. Listen for the dial tone.
Step 2 Press the pound key (#).
Step 3 Press the Menu button, press 4 on the dialpad for Speed Dial and use the Navigaion button to select the speed-dial button that you want to program. A short beep confirms that you are starting to program this button.
Step 4 Enter the speed-dial number. The digits will appear on the phone display. When you are entering speed-dial numbers on a Cisco Unified IP Phone 7912G, use the backspace (<<) soft key to erase digits that were entered incorrectly.
To remove a speed-dial number without replacing it with a new one, press the pound key (#).
Step 5 Press the same speed-dial button a second time to indicate that you have finished entering the speed-dial digits and to store the new speed-dial number.
Step 6 Hang up the handset, or press a new speed-dial button and repeat the process.
http://www.cisco.com/en/US/products/hw/phones/ps379/products_user_guide_chapter09186a00801aea8f.html#wp1047631
