Connect IP Phone 7911g to Grandstream UCM6510
We are in possession of some cisco 7911g that we want to connect to a IP-PBX Grandstream UCM6510 based on Asterisk.
We created the TFTP server and added the option on the DHCP. The phone gets the SIP firmware and an IP address but doesn't register with the PBX.
We tried some configuration files that the phone gets with TFTP but it still doesn't register.
We succesfully registered some softphone on the PBX so we think that the problem is within the 7911g configuration
The config is attached
Any Help on this will be highly appreciated.
11 Replies 11
Leo Laohoo
NOTE:  I have never tried configuring 791x for Asterisk.
The filename is incorrect.  The correct filename should be:
SEP0021A0D9C36B.cnf.xml
I tried SEP in the first place and it wasn't working so i tried SIP...
Either way doesn't work...
Does the TFTP have any logs to determine if the phone is actually doing anything?
Is the phone even getting a valid IP address?  If it is, what happens if you put the phone's IP address into a browser?
Yes, the phone get the config from the TFTP and an IP address.
When you get the IP in the browser, you get the cisco page for 7911 with all the configuration of the phone.
This interface doesn't let you modify anything though...
The intention was not to modify using the browser.
On the first page, Device Information, look at the bottom of the page.  Look at the Time, Timezone and Date.  Are they correct or not?
Next, go to the left side and click on the Device Logs and then Status Messages.
Post everything in there here.  I want to see what the phone is doing.
It seems that the date is wrong...
here are what's displayed :
home :
MAC Address 0021A0D9C36B
Host Name SEP0021A0D9C36B
Phone DN
App Load ID jar11sip.9-2-1TH1-13.sbn
Boot Load ID tnp11.3-0-1-32.bin
Version term06.default
Hardware Revision 7.1
Serial Number FCH124897NG
Model Number CP-7911G
Message Waiting No
UDI phone
Cisco Unified IP Phone 7911G, Global
CP-7911G
V07
FCH124897NG
Time 1:47:44p
Time Zone
Date 05/11/11
System Free Memory 9742496
Java Heap Free Memory 1133232
Java Pool Free Memory 277104
FIPS Mode Enabled No
logs :
1:34:51p No Trust List Installed
1:34:51p SEP0021A0D9C36B.cnf.xml
Time and date are wrong because the tags are incorrect.
<proxy>10.42.69.48</proxy>
Use "USECALLMANAGER".
Factory-reset the phone and let it download the above-mentioned change to the config.
I changed the config (i found some config online and i tried) (see attached)
The date seems still wrong though
now the logs show :
1:43:59p No Trust List Installed
1:43:59p SEP0021A0D9C36B.cnf.xml
1:44:00p Error Verifying Config Info
<transportLayerProtocol>4</transportLayerProtocol>
This value may work with CUCM but it does not work for Asterisk.
It is either 1 for TCP, 2 for UDP and 3 for TLS.
Make sure NAT and ALG are disabled between the phone and Asterisk.
I changed my configuration with your mentions but it stays in the unprovisionned state.
After a bit of recherches, I found on the html page of the phone (when I type the IP on a browser) that the UCM address 1 is my TFTP instead of my PBX.
My PBX doesn't have a TFTP server integrated so I have the TFTP on my laptop instead...
I tried to change this variable this afternoon but I didn't found any lead...
If you have any tips on how to change this I would love to hear about it
Thanks for all your answers by the way !
This is fine (and expected).  I am not worried about that.
Go back to the Status page and find out if anything has changed.  I am more interested if the SEPmacaddress.cnf.xml file contains tag errors or not.
