01-31-2021 10:38 PM
Hello. Been googling for information about the CUCM system reports call types (Internal, Local, Long Distance, etc). I wanted to know how the call type is determined. Is it from the router filter?
01-31-2021 11:58 PM
for incoming call your service provider would have to mark it accordingly, for outgoing calls you can check the link for details as it can be done both on CUCM and GW.
let us know if you have any specific question after going through the link.
JB
(Rate if it help!)
02-05-2021 11:47 AM - edited 02-05-2021 11:48 AM
For these reports to work properly, you need to manually define the type of calls on the CAR page > System > System Parameters > Dial Plan Configuration.
