06-16-2003 03:54 AM - edited 03-13-2019 12:20 AM
Does DIRT work with 4.02? I just downloaded ver 1.0.92 and installed it. When I try to run the application I get a dialog box labeled UnityDisasterRecoveryBACKUP "This utility only works with Unity 3.0(1) and later. Exiting....
Whats the scoop?
06-16-2003 04:15 AM
Yes it should work. Have a look at http://www.answermonkey.net/App_DisasterRecoveryTools.htm.
Compatibility:
Unity 3.1(1) and later
Unity 4.0(1) and later
What are you seeing when you open the saweb page? Does it correctly reflect 4.0.2 there?
06-16-2003 06:19 AM
yes, it should work fine on 4.0(2) - I just downloaded the same version and ran it on my 4.0(2) release system and it works fine.
Can you tell me what values are in the registry under "HKLM\Software\Active Voice\Build Number" and "HKLM\Software\Active Voice\Version Number"?
