DSP and toll bypass (how to use DSP Calc)
hepark
If I'm deploying G.729 across WAN and G.711 inside LAN in a 2-site IPT, with one voice gateway with PSTN termination, as PSTN connectivity is typically always via G.711, in which field on DSP Calculator should I provision the number of toll bypass calls, as terminated in G.729? Or should I fill out the number of xcode sessions field instead?
Another question: when provisioning mixed confs (G.711/G.729 users), the same DSP is also performing xcode, and which type of code is the audio being mixed to?
Thank you
beth-martin
Level 5
Level 5
You can fill out the number of xcode sessions field
