04-24-2017 11:42 AM - edited 03-13-2019 09:52 PM
I have the new Spark firmware for the DX80. How do I enable extending my laptop so that it works as a monitor? I used to be able to do this with the old DX80 firmware.
Thanks.
Solved! Go to Solution.
08-14-2017 07:31 PM - edited 08-21-2017 05:12 PM
Take a look at the DX80 Install Guide it covers connecting your laptop to the DX80. There are two HDMI ports, one is an input and the other an output, only the HDMI input is currently used while the output is reserved for future use.
08-14-2017 01:40 PM
Hi, as an update. I called into Support. On the back of the unit there are two inputs to choose. If the input you are using doesn't allow the DX80 to be used as a monitor, then plug into the other one.
