Enabling and Disabling Call Forwarding remotely
athazhayil
We are currently using Cisco Unified Call manger ver.5.1.2
If I have my office Cisco phone enabled call forwarding to my cell and I am on the road, is it possible to remove the call forwarding from my Office Cisco office phone remotely? (Without login to CCM User Web page and modifying CFwdALL settings) Any suggestion / tips are appreciated.
Thanks in advance
Alex
Jaime Valencia
No, you need to do this either via WEB or on phone.
I would look into SNR with 6.X and 7.X instead.
java
if this helps, please rate
java
Jaime Valencia
java
java
