extended service installation problem
rachelau_2004
I am trying to install extended service 3.1.3 on call manager 3.3.3
during installation, i receive the following error:
setup initization error: set up is unable to find installation languages in C:\ sti\stage\apps\service\SETUP.LID files
error 105
I saved the file (cm-es-ffr.3-1-3.exe) under C drive and then run it from there.
when under the Apps folder, there is only CiscoCRA folder but no Service folder.
please advice .
Thanks.
pradeepde
Level 5
Level 5
I suspect the problem is with the extended service.You can also try to restart the CCM
