Forwarding Calls to T-Mobile Cell Phone?
tracy
Is anyone else having trouble forwarding their lines to a T-Mobile Cell Phone, I have no problem with verizon or other carriers just T-Mobile it will just go busy.
trailman73
Level 4
Level 4
I have a couple of users that use T-mobile without incident. you may check your route patterns, and make sure that they are in the Calling Search Space you are using.
Geoff
