The call is not disconnected when originated from PSTN, that is, FXO port in 1750 remains up. If I change to ground-start the call isn't answered by FXO port.
If ground-start signaling does not fit the problem, you can also try some other alternatives, please follow the guideline http://www.cisco.com/warp/customer/788/signalling/fxo_disconnect.html
Learn, share, save
