Hi Jaleel,
Which IOS version and CCM version you are running?
It may be related to these DDTS, they explain why the FXO port is transitionint to OFF-HOOK state.
Are you using LS or GS?
CSCdu84171
Externally found enhancement defect: New (N)
mgcp ls endpoints should not go offhook until connect.
CSCdu84215
need plar opx functuality with mgcp for analog loop start trunks.
You can configure the gateway as H.323 with connection plar opx command.
//G
