H323 Dial Plan- IP with Both FXS Ports and Regular Dial Plan with 2 FXS
ab0809742006
Is there a way i can dial a back to back ATA 186?
I would need two scenarios:
1. IP Dial Plan - it is working on FXS Port0 but how can i dial FXS Port1 using IP Dial plan?
2. Normal Dial Plan - How can i dial a device using the UID? Can you give me a sample on this scenarion.
Thanks and hope you understand my query...
Arthur
ab0809742006
By the way i am using 2 Cisco ATA 186 Back to Back configuration.
Thanks..
Arthur
I am very sorry if you don't understand what i mean on my query.
I am using a Cisco ATA 186 Analog Telephone Adaptos using H323 back to back configuration.
Now with IPDial plan i successfully call the port 1 while the port 2 for FXS i could not connect..
and because i don't have any idea on dialing plan for this ATA device.
Can anyone help me on this problem, even though it is ip dialing no problem as long as i can connect to the 2nd fxs port.
Thanks in advance and i hope you can help me on this matter..
Arthur
Can anyone help me on this?
