H323 Gateway and Interface Dialer
wongsusanto
I tried to configure the h323 gateway under the dialer interface, it is able to register itself to gatekeeper..but unable to make a call.........i can see it in the gatekeeper.....does it matter if i configure the dialer interface as h323 gateway,,,,,,,, ? is there anyone can help me to solve this problem ?
thanks
gateway
interface Dialer1
ip address negotiated
encapsulation ppp
dialer pool 1
dialer-group 1
ppp pap sent-username test1 password 7 00101615100A
h323-gateway voip interface
h323-gateway voip id LGAVoIPGk ipaddr xx.xx.xx.xx 1718
h323-gateway voip h323-id LGACustVoIP
h323-gateway voip tech-prefix 3000#
debug ras on gateway
voip_gw#csim sta 1176740016597818591
csim: called number = 1176740016597818591, loop count = 1 ping count = 0
csim err csimDisconnected recvd DISC cid(29)
csim: loop = 1, failed = 1
csim: call attempted = 1, setup failed = 1, tone failed = 0
voip_gw#h323chan_dgram_send:Sent UDP msg. Bytes sent: 193 to xx.xx.xx.xx:1719
May 13 14:30:48.045: RASLib::GW_RASSendARQ: ARQ (seq# 102) sent to xx.xx.xx.xx
May 13 14:30:48.057: h323chan_chn_process_read_socket
May 13 14:30:48.057: h323chan_chn_process_read_socket: fd (2) of type CONNECTED
has data
May 13 14:30:48.061: h323chan_chn_process_read_socket: h323chan accepted/connected
May 13 14:30:48.061: h323chan_dgram_recvdata:rcvd from [xx.xx.xx.xx:1719] on sock[2]
May 13 14:30:48.065: ARJ (seq# 102) rcvd
gatekeeper
R8#sh gatek gw
GATEWAY TYPE PREFIX TABLE
Prefix: 117674#*
Zone LGAVoIPGk master gateway list:
yy.yy.yy.yy:1720 LGAVoIPGw
Prefix: 2000#*
zz.zz.zz.zz:1720 BR2
Prefix: 3000#*
nn.nn.nn.nn:1720 LGACustVoIP
gatekeeper
zone local LGAVoIPGk lga.net.sg xx.xx.xx.xx
accounting vsa
security token required-for all
no shutdown
ciscomoderator
Community Manager
Community Manager
Often times complex troubleshooting issues are best addressed in an interactive session with one of our trained technical assistance engineers. While other forum users may be able to help, it’s often difficult to do so for this type of issue.
To utilize the resources at our Technical Assistance Center, please visit http://www.cisco.com/tac and to open a case with one of our TAC engineers, visit http://www.cisco.com/tac/caseopen
If anyone else in the forum has some advice, please reply to this thread.
Thank you for posting.
