HELP!! CCM and directory
rywalker
Hi all, I just upgraded my pub to version 3.3.3 and now the phone will not display the directory. It says host not found. On the CCM page I can add a user ok. But when I go to search I get
The following error occurred while trying to load the requested page.
Error in processing.\n userObj.getMaxSearchEntries()
[object Error]
I am not intergrated with AD
Any ideas
thisisshanky
Level 11
Level 11
You need to first go to,
System - > Server - select each server and change the hostname field from HOSTNAME field to IP address, unless you are using DNS.
Now go to System - >Enterprise parameters
where ever there is a hostname reference to the Callmanager (the help URL, Directory URL etc), change it to IP address.
Sankar Nair
UC Solutions Architect
Pacific Northwest | CDW
CCIE Collaboration #17135 Emeritus
Thanks alot, that solved the issue
