09-08-2010 06:10 AM - edited 03-13-2019 07:08 PM
Hi guys, i'm trying to implement this design but failed. Please help me to clarify what had went wrong.
I have a running CME 4.0 and it is working fine. What i'm going to do is pass 2 dn to IPC Alliance system. Due to insufficient card slot, I've purchased another router with VWIC-1MFT. The problem is controller E1 that i've configured in router B wont establish (down). I'm using 1-2,4-5 connector and I've tried with loopback test on router and it works fine.
router A (forward the 2 dn to router B)
dial-peer voice 6666 voip
description **forward to voice_gw**
destination-pattern 6666
session target ipv4:192.168.10.3
dial-peer voice 6600 voip
destination-pattern 6600
sh dial-peer voice summary
6666 voip up up 6666 0 syst ipv4:192.168.10.3
6600 voip up up 6600 0 syst ipv4:192.168.10.3
router B (grab dn from router A and pass them to IPC)
clock timezone MY 8
network-clock-participate wic 0
voice-card 0
controller E1 0/0/0
framing NO-CRC4
ds0-group 1 timeslots 1-2 type e&m-melcas-immed
voice-port 0/0/0:1
dial-peer voice 6600 pots
port 0/0/0:1
prefix 6600
dial-peer voice 6666 pots
port 0/0/0:1
prefix 6666
sh controller e1
E1 0/0/0 is down.
Applique type is Channelized E1 - balanced
Cablelength is Unknown
Transmitter is sending remote alarm.
Receiver has loss of frame.
alarm-trigger is not set
Version info Firmware: 20090408, FPGA: 13, spm_count = 0
Framing is NO-CRC4, Line Code is HDB3, Clock Source is Line.
Data in current interval (120 seconds elapsed):
0 Line Code Violations, 0 Path Code Violations
0 Slip Secs, 0 Fr Loss Secs, 0 Line Err Secs, 0 Degraded Mins
0 Errored Secs, 0 Bursty Err Secs, 0 Severely Err Secs, 120 Unavail Secs
Total Data (last 3 15 minute intervals):
17020 Line Code Violations, 24 Path Code Violations,
4 Slip Secs, 0 Fr Loss Secs, 0 Line Err Secs, 0 Degraded Mins,
4 Errored Secs, 0 Bursty Err Secs, 0 Severely Err Secs, 2650 Unavail Secs
09-08-2010 07:41 AM
Does the IPC system need to be connected with a straigth or cross-over E1/T1 cable? If cross-over, the pin out is 1-4 2-5. It's worth a try if you can make the cable. Also, check the framing and line code configuration and make sure they match with the IPC system.
-Felipe
09-08-2010 06:48 PM
yes it is using the crossover cable, framing and linecode is match as well. i was thinking whether the setup shouldnt be done this way or there is a better way to do this using same hardwares.
09-09-2010 08:28 AM
Is the pinout for the cross-over cable 1-4 2-5?
-Felipe
04-24-2013 08:56 AM
Did you manage to integrate CME with IPC alliance system
if yes, can you please share some configuration steps
shameer
