11-18-2002 09:34 AM - edited 03-12-2019 09:36 PM
Some phones from being able to call 1411.
Solved! Go to Solution.
11-18-2002 09:54 AM
You have to create a different Calling Search Space .
Where the Partion or partions that have the Filter or route pattern to dial 411 is
not available in the Search Space where the phones you want to block are set to,
Example:
partion 411
partion Internal
partion Local Calls
Partion Long Distance Calls
CSS: No 411 calls
Partions Available= Internal, Local Calls , Long Distance Calls,
CSS: All Calls
Partions Avaiable= 411, Internal , Local Calls, Long Distance Calls,
Hope this Helps
There will also be a Filter associate with Services. ie. 411,611,911.
Have a Good Day
Pablo
11-18-2002 09:54 AM
Example:
partion 411
partion Internal
partion Local Calls
CSS: No 411 calls
CSS: All Calls
Hope this Helps
Have a Good Day
Pablo
11-20-2002 06:39 AM
Thanks.. This is exactly what I was looking for...
11-19-2002 09:04 PM
The easiest way is to block those numbers on the network side, I.e. on the GK, SIP proxy or at the MGW,
It is depend on your layout
