01-30-2003 01:44 AM - edited 03-12-2019 10:29 PM
Dear Forum,
My name is Yohan Gunawan from Indonesia.
I have a set up with requirement as below:
two cisco router 2621 back to back
bandwith 64kbps each
router ospf
LAN HQ=10.10.2.1/25
LAN Branch=10.1.1.1/25
HQ Branch
.241 10.1.1.240/30 .242 Link1
8801 P1 ---------------------- P1 1101
2621 2621
8802 P2 ---------------------- P2 1102
.245 10.1.1.244/30 .246 Link2
P1 & P2 is analog phone 1 & 2 with the number: 88xx @ HQ and 11xx @ branch
The requirements are (refer to the diagram):
1. Branch has 2 connection to HQ: link1 10.1.1.240/30 and link2 10.1.1.244/30
2. Routing Protocol: OSPF
3. link1 is for data; link2 for voice (say 2 channel voice)
4. upon link1 failure, data is routed through link2. Since link2 is shared by data and voice. voice channel need to be reduced to 1 channel only
I have tried RSVP to reserved 1st call, but how do I make the 2nd call (considering the way call-rsvp is configured in dial-peer)
If I reserved 2 call (as per config attached), then data will not use the bandwith as it is reserved by the voice traffic (ip rsvp bandwith 48)
I havent been able to deliver item 4 requirement with this idea (as per config I attach).
Do you have any idea how to do this. As far as I know cisco does not have a specific feature that match exactly with this requirement.
Thank you very much
Yohan
router config:
Branch_1#sh run
Building configuration...
Current configuration : 2105 bytes
version 12.2
hostname Branch_1
enable password cisco
memory-size iomem 10
ip subnet-zero
ip cef
no ip domain lookup
ip audit notify log
ip audit po max-events 100
voice call carrier capacity active
fax interface-type fax-mail
mta receive maximum-recipients 0
interface Loopback0
description Loopback Address for OSPF
ip address 10.1.1.254 255.255.255.255
interface Loopback1
description LOOPBACK FOR VOICE CONNECTIVITY
ip address 10.1.1.253 255.255.255.255
ip route-cache policy
ip policy route-map voice
h323-gateway voip bind srcaddr 10.1.1.253
interface FastEthernet0/0
description DATA Network
ip address 10.1.1.1 255.255.255.128
duplex auto
speed auto
interface Serial0/0
bandwidth 64
ip address 10.1.1.242 255.255.255.252
no fair-queue
interface FastEthernet0/1
no ip address
shutdown
duplex auto
speed auto
interface Serial0/1
bandwidth 64
ip address 10.1.1.246 255.255.255.252
fair-queue 64 256 2
ip rsvp bandwidth 48 48
router ospf 1
log-adjacency-changes
network 10.1.0.0 0.0.255.255 area 1
ip local policy route-map voice
ip classless
ip http server
access-list 110 permit ip host 10.1.1.253 any
access-list 110 permit tcp any any eq 1720
route-map voice permit 10
match ip address 110
set ip next-hop 10.1.1.245
route-map voice permit 20
set ip next-hop 10.1.1.241 10.1.1.245
call rsvp-sync
voice-port 1/0/0
voice-port 1/0/1
mgcp profile default
dial-peer cor custom
dial-peer voice 1 pots
destination-pattern 1101
port 1/0/0
dial-peer voice 2 pots
destination-pattern 1102
port 1/0/1
dial-peer voice 10 voip
destination-pattern 88..
voice-class source interface Loopback1
session target ipv4:10.10.2.253
req-qos controlled-load
acc-qos controlled-load
ip qos dscp cs5 media
line con 0
exec-timeout 0 0
logging synchronous
line aux 0
no exec
transport input all
line vty 0 4
exec-timeout 0 0
password cisco
logging synchronous
no login
end
Branch_1#
Branch_1#sh ver
IOS (tm) C2600 Software (C2600-IK8O3S-M), Version 12.2(11)T3, RELEASE SOFTWARE
(fc2)
TAC Support: http://www.cisco.com/tac
Copyright (c) 1986-2002 by cisco Systems, Inc.
Compiled Sun 22-Dec-02 02:34 by ccai
Image text-base: 0x8000809C, data-base: 0x8181F4BC
ROM: System Bootstrap, Version 12.1(3r)T2, RELEASE SOFTWARE (fc1)
Branch_1 uptime is 22 hours, 21 minutes
System image file is "flash:c2600-ik8o3s-mz.122-11.T3.bin"
cisco 2621 (MPC860) processor (revision 0x600) with 59392K/6144K bytes of memory
Processor board ID JAD05220NVS (4116991722)
M860 processor: part number 0, mask 49
Bridging software.
X.25 software, Version 3.0.0.
2 FastEthernet/IEEE 802.3 interface(s)
2 Serial(sync/async) network interface(s)
2 Voice FXS interface(s)
32K bytes of non-volatile configuration memory.
32768K bytes of processor board System flash (Read/Write)
Branch_1#
HQ_Voice_GW#sh run
Current configuration : 2103 bytes
version 12.2
hostname HQ_Voice_GW
ip subnet-zero
ip cef
no ip domain lookup
ip audit notify log
interface Loopback0
description OSPF ROUTER ID
ip address 10.10.2.254 255.255.255.255
interface Loopback1
ip address 10.10.2.253 255.255.255.255
h323-gateway voip bind srcaddr 10.10.2.253
ip address 10.10.2.1 255.255.255.128
duplex auto
speed auto
interface Serial0/0
bandwidth 64
ip address 10.1.1.241 255.255.255.252
no fair-queue
clockrate 64000
no ip address
shutdown
duplex auto
speed auto
interface Serial0/1
bandwidth 64
ip address 10.1.1.245 255.255.255.252
--More--
*Mar 1 22:21:44.384: Writing Reservation Timer to Running Config 10000
fair-queue 64 256 2
clockrate 64000
router ospf 1
network 10.1.1.240 0.0.0.7 area 1
network 10.10.0.0 0.0.255.255 area 0
ip classless
ip http server
access-list 110 permit ip host 10.10.2.253 any
set ip next-hop 10.1.1.246
set ip next-hop 10.1.1.242
call rsvp-sync
voice-port 1/0/0
voice-port 1/0/1
destination-pattern 8801
port 1/0/0
destination-pattern 8802
port 1/0/1
destination-pattern 11..
session target ipv4:10.1.1.253
line con 0
exec-timeout 0 0
logging synchronous
line aux 0
exec-timeout 0 0
no exec
transport input all
line vty 0 4
exec-timeout 0 0
password cisco
logging synchronous
no login
end
HQ_Voice_GW#
HQ_Voice_GW#sh ver
(fc2)
ROM: System Bootstrap, Version 12.2(6r), RELEASE SOFTWARE (fc1)
HQ_Voice_GW uptime is 22 hours, 22 minutes
cisco 2651 (MPC860P) processor (revision 0x00) with 125952K/5120K bytes of memor
y.
Processor board ID JAD06080GPD (3036985697)
M860 processor: part number 5, mask 2
Bridging software.
HQ_Voice_GW#
02-06-2003 07:48 AM
I think the support for this feature is not available currently. There is only fallback for call admission control.
