How to put a pause in dial string
parisatashakori
Hi everybody,
I have a question regarding to possible dial strings. In a softkey url we have Dial:n uri and
we want to specify pause between dialled numbers. How is it possible?
Parisa
5 Replies 5
travis-dennis_2
Level 7
Level 7
If I understandd you correctly and if my memory serves (probably not) you can put a comma in the dial string for a pause. One comma equals about 3 seconds of pause. You can use multiple commas for longer pauses.
Hope this helps.
Please remember to rate all replies
Thanks for your reply. Unfortunately this doesn't work, Is there any other idea?
Parisa
jlaurence
From the researching I've done on various forums, including this one, there is not a way to include a pause in the dial string or speed dials. There is a bug, CSCec41905, for the pause in speed dials. I'm assuming that they'll allow a pause in dial strings when they allow the pause in speed dials.
Jesse
francis.labelle
Do you know if this "feature" is now available with CallManager 4.1sr2 ?
Unfortunately, it's not solved yet.
