How to Reset Voicemail Pin for CP8841
curtis.l.lipski
Hello, In my office, many of us are users of the CP8841 phone, however we are lacking manuals that show us how to set up things on the phone. The main things I want to be able to do is set the pin for my voicemail. When I select voicemail, the phone asks me to put in the pin number, however, I have never set it up before, so I am wondering how I can have the pin number reset.
Jaime Valencia
What you're asking has nothing to do with the phone model, that depends on the system you're using for voicemail, you need to reach out to your local IT for assistance with this, they should either tell you the default PIN they configured, reset it for you, or provide a web page where you can change it yourself.
java
if this helps, please rate
