Incoming ring times
pharden
We have several centers set up with CCM. When we call into these centers it takes two sometimes three rings then you hear a ..skip in tone(You also can see it in the Router under voice call sum) The skip is when it finally reaches the receptioists phone and is ringing. Is there a timer to decrease the time it takes to hit the first set and start ringing?
sgossen
Level 4
Level 4
What type of connection do you have to the PSTN? I would guess POTS lines connected to FXO cards? If so, my guess would then be that the router is waiting on caller id before it picks up the call.
This may help:
http://www.cisco.com/en/US/customer/tech/tk652/tk653/technologies_configuration_example09186a00800a9a49.shtml
Good luck,
Scot
