Open up the AC settings, goto the advanced tab and check "enable trace". Try logging in again, and then take a look at the file c:\program files\cisco\Call Manager Attendant Console\logs\jtapi\CiscoJTAPIxxx.log
Look for the ProviderOpenRequest, and the messages that immediately follow. In particular, the ProviderOpenCompletedEvent should give you a failure description.
