IP-AA does not register after TAPS was installed, JTAPI stays PARTIAL-SERVI
LESTERCAM
On the CCM v3.2 the TAPS/BAT was first installed and works fine eventhough the JTAPI service is showing PARTIAL_SERVICE and all looks ok qua config.
When I added AA following the guidelines (standard 1 CTI-RP and 4 CTI phones & the user + the app in the end) the AA would not register i.e. the AA-CTI-RP I created for AA stayed in a status 'not found' while the RP-TAPS shows nicely registered to the CCM.
TASP is still working fine but calling the AA route point gets a busy tone.
The CTI follow (taps 5010-5011 and AA 5012 till 5015), CTI-RP's are 5001 for TAPS and resp. 5002 for AA.
Hope some help from outer space...
LESTERCAM
Hip Hip, I found it by chance.
The "user" for AA and TAPS must be the same so that in the Device Assocoations fo rthat user you get TAPS and AA CTI-ports and CTI-RP's all together. And ... for AA the 'No primary Extension' must be set which is not required for TAPS.
Easy when you know it.
Leo Jo Estercam
