Level of latency and jitter
f.campos
I would be grateful if anyone could tell me the maximum level of latency and jitter in a network IP that can be supported by a videoconference system H323.
The system is comprised of terminals Picturetel, Polycom, MCU and gateway Cisco.
9 Replies 9
mmellet
Level 3
Level 3
I would guess latency somewhere around 70 milliseconds. Has anyone seen a definite number? I know it’s low.
One book from Cisco is saying better less than 125 msec, no more than 150 msec (round-trip)for interactive real-time video or audio. But I think it is only a recommendation, which level you would like to use is really depends on your clients' expectation for video and audio quality...
I agree with maxiaojia. Under 150msec is the benchmark you are looking to achieve. I may be working a project like this in the near future and would like to know what your outcome is.
150 msec round trip ? I keep getting conflicting information on this.. I've read 150 msec one way.
Which is it ? one way or round trip ?
The ITU recommends no more than 150ms round trip
ITU-T's G.114 Specification recommends 150sec ONE-WAY delay; mouth to ear for real-time applications, however, video applications are less sensitive to delay with respect to voice.
BR,
Charles - Ebone
It's great to finally find some answers to this question, but just to be totally clear about this (if possible)...
Here:
Networked Multimedia Overview
http://www.cisco.com/warp/public/614/19.html under latency it says that it has to be under 400ms. Is this just the maximum latency that the call can have while still maintaining a connection, and that and delay under 150ms means that the delay/latency won't be a factor in the overall quality?
As well, what is the recommended/minimum/maximum jitter...
or are all of these questions too product specific?
zabriskis
For a discussion on this see the white paper iPower Reliability and IP Precendence, it is on the last couple of pages at http://www.picturetel.com/integrated.asp?name=intwp.xml
The PictureTel Jitter buffer is set to 150ms, whereas the Polycom is at 75ms.
