Multiple directories
p.abbeel
What is the finest way to add multiple directories behind the directory phone button of an IP Phone?
Example:
1. Company A listing
2. Company B listing
3. Company C listing (*)
For example the directory listing of Company C is a listing of shortcodes towards an external company? In other words; this listing can not be retrieved from the Call Managers.
Thanks a lot,
Peter
p.abbeel
Anyone? :-)
Check on Enterprise Parameters Configuration «Phone URL Parameters» to find out ther responsebe server for directory. On that CCM server open file: c:\CiscoWebs\IPPhoneServices\CCMCIP\xmldirectory.asp
In file find
<% = outputString( dictionary.xmldirectoryMsgPagePrompt, "dictionary.xmldirectoryMsgPagePrompt" ) %>
<% = outputString( dictionary.lblCorporateDirectory, "dictionary.lblCorporateDirectory" ) %>
<% = getBaseURL() %>xmldirectoryinput.asp
and insert this before last line () :
Company A listing
http://web_A/directory.asp
Company B listing
http://web_B/directory.asp
Company C listing
http://web_C/directory.asp
this will add 3 more line (menu item) in Directory.
I hope this help you.
How does the script (directory.asp) looks like for each individual directory? Do you have an example of this?
Thanks a lot for your help,
Peter
directory.asp is only name example. In URL section you put http link to same web server where you make application that search your database. Find out same web developer to make that application for you if you are not web developer. You can look to source code on CCM server in folder c:\CiscoWebs\IPPhoneServices\CCMCIP. The file for this is xmldirectoryinput.asp (search criteria input) and xmldirectorylist.asp (search response); here you can see how it looks like.
