No Audio With VoIP Gateway
admin_2
Level 3
Level 3
I have a problem with no Audio on VoIP gateways. Specifically this is an H.323 gateway.
I have encountered this at several customers and tried a number of versions of code. IP routing is enabled.
And all best practices implemented.
Any ideas?
Not applicable
There may be many reason why you have one way
voice call.
1. You could have a codec missmatch and hence can
hear audio.
2. The ipaddress used for the return call leg may be wrong
and unreachable ( maybe loopback ip as I've seen this happen
before).
