Outgoing calls at ATA 186
h.herden
I have a problem with ATA 186 (Version v2.15) in H.323 Mode. The ATA is configured as H.323 Client at CallManger Version 3.2(2c). Incoming calls at the ATA work properly, but outgoing calls don't. I can hear the dial tone at the analog phone, but dialing doesn't take effekt.
Hannes
rickb
Level 3
Level 3
Dial tone is locally generated from the ATA, so it would generate that pretty much regardless of the situation. First step is to check the CallingSearchSpace associated with the ATA. Can you not dial outside or inside, or can you dial inside phones?
Rick
Thanks for your help.
I don't use CallingSearchSpace. I have a very small network (5 phones) for testing CallManager funktions. I am able to call the analog phone from another, the speech connection also work properly, but it's not possible to place calls at the analog phone.
Try to punch the pound key after dialing out phone numbers.
aayeras
Hannes,
I think the problem is your Codec Settings, it should match the settings of your callmanager to your LBR Codec, AudioMode, TXcodec and RXcodec. Try these config it Might Help.
LBR Codec = 3
AudioMode = 0x00000002
RxCodec = 2
TxCodec = 2
Goodluck
