10-11-2001 12:15 PM - edited 03-12-2019 12:52 PM
With a page control unit plugged into an FXS port, what configuration do I need to put under the port so that the page control unit Auto-Answers? Right now, I just hear ringing through the paging speakers.
10-11-2001 12:56 PM
What kind of page control unit do you have installed currently?
10-12-2001 05:26 AM
The unit is a Valcom V-2001A. It is connected to a VG-200 FXS port. The VG200 is configured as an H.323 gateway.
10-12-2001 06:34 AM
The V-2001A is a trunk port paging control. It must be used with a FXO port. You can get an adapter to use the FXS port; A Valcom V-9940 or V-9970 should do the trick.
