10-10-2002 02:16 AM - edited 03-12-2019 09:06 PM
what's the distance limitation for the rj48c cable to connect a pbx to c3640's nm-hdv-e1 module? i heard it depends on the awg of the cable, anybody have a pointer?
10-16-2002 10:50 AM
I do not see any problems up to 200m using 26 awg cable.
10-18-2002 02:53 AM
I've run a PRI circuit over standard telephony cable more than 200m before now, works fine.
Paul
