08-31-2008 08:10 PM - edited 03-13-2019 05:36 PM
Is there any other way to lock a phone, aparts from COR or call blocking??? I'd like the allow users to login make calls and when the call ends the login access also ends, therefore, the next call they will be required to login again??? Is there anything out there?
09-01-2008 01:04 AM
You can use third party XML service
09-02-2008 02:17 PM
which would you recommend?
