Play in future does not work
dtapia
I have a DMM with 5.2 release and it is working fine but, the option play in future does not work. It did not open the windows and not showed any thing.
I have tried to run play in future option with some java ( 1.6.0, 1.6.0_01, 1.6.0_04, 1.6.0_07 and 1.6.0_18 ) release but, It have not worked.
What release should I use to run this option?
Thanks and Regards.
6 Replies 6
max_solovyov
I have the same problem. DMS v.5.2
Version 5.2 is not really Java nessary. Upgrade your flash and see if that works better for you. I had the same issue when I was working with the DMD portion of 5.2 and found it was not a Java issue but insted it was a old version of flash that was messing me up. Upgraded Flash 10 and it was all good after that.
JP
Still does not work
Here is the errors list from Java console
2    [AWT-EventQueue-2] ERROR respond.SetApplicationsMarshaller::fromXml  - Cannot init Applications from XML...
java.lang.IllegalArgumentException: Illegal pattern  character 'M'
    at java.text.SimpleDateFormat.translatePattern(Unknown Source)
    at java.text.SimpleDateFormat.applyLocalizedPattern(Unknown Source)
    at com.cisco.dm2bu.ds.client.scheduler.data.ScheduleSimpleDateFormat.parse(ScheduleSimpleDateFormat.java:64)
    at com.cisco.dm2bu.ds.client.scheduler.data.ScheduleSimpleDateFormat.(ScheduleSimpleDateFormat.java:46)
    at com.cisco.dm2bu.ds.client.scheduler.data.marshaller.object.ApplicationMarshaller.createApplications(ApplicationMarshaller.java:66)
    at com.cisco.dm2bu.ds.client.scheduler.data.marshaller.respond.SetApplicationsMarshaller.fromXml(SetApplicationsMarshaller.java:58)
    at com.cisco.dm2bu.ds.client.scheduler.data.marshaller.MarshallerController.fromXml(MarshallerController.java:108)
    at com.cisco.dm2bu.ds.client.scheduler.utils.EventHandling.processGetApplicationsExternalEvent(EventHandling.java:123)
    at com.cisco.dm2bu.ds.client.scheduler.gui.SchedulerApplet.initSchedulerData(SchedulerApplet.java:239)
    at com.cisco.dm2bu.ds.client.scheduler.gui.SchedulerApplet.initSchedulerApplet(SchedulerApplet.java:197)
    at com.cisco.dm2bu.ds.client.scheduler.gui.SchedulerApplet.access$000(SchedulerApplet.java:51)
    at com.cisco.dm2bu.ds.client.scheduler.gui.SchedulerApplet$1.run(SchedulerApplet.java:172)
    at java.awt.event.InvocationEvent.dispatch(Unknown Source)
    at java.awt.EventQueue.dispatchEvent(Unknown Source)
    at java.awt.EventDispatchThread.pumpOneEventForFilters(Unknown Source)
    at java.awt.EventDispatchThread.pumpEventsForFilter(Unknown Source)
    at java.awt.EventDispatchThread.pumpEventsForHierarchy(Unknown Source)
    at java.awt.EventDispatchThread.pumpEvents(Unknown Source)
    at java.awt.EventDispatchThread.run(Unknown Source)
700  [AWT-EventQueue-2] ERROR respond.InitSetSchedulesMarshaller::fromXml  - Error during XML parsing...
    at com.cisco.dm2bu.ds.client.scheduler.data.marshaller.respond.InitSetSchedulesMarshaller.initSchedulerDateSettings(InitSetSchedulesMarshaller.java:103)
    at com.cisco.dm2bu.ds.client.scheduler.data.marshaller.respond.InitSetSchedulesMarshaller.fromXml(InitSetSchedulesMarshaller.java:52)
    at com.cisco.dm2bu.ds.client.scheduler.utils.EventHandling.processGetInitSchedulesExternalEvent(EventHandling.java:111)
    at com.cisco.dm2bu.ds.client.scheduler.gui.SchedulerApplet.initSchedulerData(SchedulerApplet.java:241)
Exception in thread "AWT-EventQueue-2" java.lang.NullPointerException
    at com.cisco.dm2bu.ds.client.scheduler.gui.baseview.BaseViewPanel.initTopNavigPanel(BaseViewPanel.java:154)
    at com.cisco.dm2bu.ds.client.scheduler.gui.baseview.BaseViewPanel.(BaseViewPanel.java:98)
    at com.cisco.dm2bu.ds.client.scheduler.gui.SchedulerApplet.initSchedulerGui(SchedulerApplet.java:279)
    at com.cisco.dm2bu.ds.client.scheduler.gui.SchedulerApplet.initSchedulerApplet(SchedulerApplet.java:200)
Hi Max,
I found that this issues is present in 5.0.2 version too, If you pc works with WinXP try to do this:
Go to the control panel
  --> double clicl on Regional and language Option
  --> choose :
--------->Standards and formats [English(Unated States]
--------->Location [United States]
Reboot Windows
-> Launch Browser and Point to DMM-DSM and test again
I hope this helps!
I have a windows 7, but i try to change  location. Unfortunately, it does not help.
I found, that on WinXP everything is fine, but on Win7 we have such problems.
Hi all,
This regional and location changing was very helpfull to me.
I have Windows XP and Windows 7.
I even didn't need to reboot windows. It works after I have change settings.
