Problem in adding IEC 4650(ver 2.5) Device in IEM 2.6
ramiline
I am trying to add IEC 4650 with 2.5 firmare in IEM 2.6.
I have followed the below steps to add the device.
1) After powering and connecting the IEC, I added the device in IEM, the status of the IEC device is OFF.
2) I tried to change the IEC from Stand-alone mode to mode to Managed mode, but I failed to do so as it says "http connection refused.".
from this i understand that http connection to IEM 2.6 is not allowed .
3) I am able to ping  from IEC to IEM and IEM to IEC as well.
I have few questions regarding this.
Will this problem be solved if I upgrade IEC firmware from 2.5 to 2.6?
Raghu
stevenjlim
Did you ever solve this. I have the same issue.
[Updated] it's ok, i found the solution was to turn on a setting in IEM under Maintenance > Server Settings > Device gateway enabled = Yes
