Problems with E1 card an Lucent G3
eduardo.ramirez
Hi I have configred my Voip Scenario on 2600 with E1 30 card conected at PBX lucent G3
When I recive calls y don't have problem the problem is when I call they can't listen to me
this is my configuration
controller E1 1/0
framing NO-CRC4
ds0-group 0 timeslots 1-12 type e&m-immediate-start
cas-custom 0
interface FastEthernet0/0
description PRUEBA VOIP
ip address xxx.xxx.xxx.xxx 255.255.248.0
duplex auto
speed auto
no mop enabled
h323-gateway voip interface
h323-gateway voip id mx-mc-gk ipaddr xxx.xxx.xxx. 1718
h323-gateway voip h323-id mx-mc-gw-1@prueba.mycompany.com
h323-gateway voip tech-prefix 1#
voice-port 1/0:0
define Tx-bits idle 1001
define Tx-bits seize 0001
define Rx-bits idle 1001
define Rx-bits seize 0001
cptone MX
timing percentbreak 60
dial-peer cor custom
dial-peer voice 5 voip
destination-pattern T
session target ras
dtmf-relay h245-alphanumeric
dial-peer voice 10 pots
destination-pattern 52559178....
port 1/0:0
gateway
Pabloduarte
Eduardo,
Can You please tell me what IOS version you have on the 2600.
Also try adding the following commands
Voice Call Send-Alert
Voice rtp send-recv.
and also add in the Voip Dial Peer.
Progress_ind setup enable 3
Hope this Helps.
Pabloduarte
One More Thing that may help.
We experienced the same problems on our intial installations.
We had to point the Call Manager to Interface Loopback address.
The command is as follows
interface Loopback0
Ip interface xxx.xxx.xxx.xxx. 255.255.248.0
h323-gateway voip bind srcaddr xxx.xxx.xxx.xxx
the Ip Address of this loopback interface will be the address of the Gateway in the Call Manager.
This should help your one-way audio problem
if not look in the Cisco site for the PDF file
Troubleshooting One way Audio
Pablo
Hi Pablo thanks for yout help
The problem was correct ed with this command
Voice rtp send-recv
So now I have other problem after some minutes the call is down .....
Do you have some about that ?
cheers
