Reload system prompts
admin_2
Level 3
Level 3
Is it possible to reload the system prompts from the original Unity install? I have a client that used the setvolume utility to increase the volume and overwrote the originals. They have since mucked with the volume to the point where the prompts are uninteligable. If so, how would I go about reloading the prompts?<br><br>
kechambe
Level 7
Level 7
Rerunning the setup is probably the easiest way to get this done. None of your current data will be changed.
Keith
Keith Chambers
Diagnostic Engineer
Voice Network Team, San Jose
Cisco Systems, Inc.
