Replication Monitor Errors - Help
cplatt01
I am getting the following error on my SQL Distribution Agent:
The process could not execute '{call sp_MSget_subscription_guid(3)}' on '<Call Manager>'.
When I run dblhelper, I have the 2 red faces :( I wanted to see if republishing this will correct the issue.
Also, I am seeing all devices have a status of not found in the Call Manager Admin. I am assuming these are related.
CM: 4.1(3) SR1
OS: 2000.7 sr8
Any help or thoughts would be great.
gogasca
Level 10
Level 10
Servers are in the same subnet?
Please give a try to DBlhelper and let us know the results.
Any errors in the Event viewer?
For the device status you might restart RIS service t see if that helps.
Reestablished SQL Database connection by using this link
http://www.cisco.com/en/US/products/sw/voicesw/ps556/products_tech_note09186a00801d11a6.shtml
Gonz
