RisPort SOAP message problem
bjpaddock
I am trying to run a query against the realtime web service in CM5 to find out an IP address of a device but I get the following soap fault:
<faultcode>soapenv:Server.userException</faultcode><faultstring>java.lang.IllegalArgumentException: java.lang.ClassCastException@32795</faultstring><detail><ns1:hostname xmlns:ns1="http://xml.apache.org/axis/">myhostname</ns1:hostname></detail></soapenv:Fault>
Please see the attached java code I use and the actual XML it sends (which appears to be correct against the documentation)
Is there anything I am missing?
Many thanks for your time
bjpaddock
I managed to solve it myself (shouldn't have been so hasty!)
For anyone's interest, "Class" and "Status" need to be of type xsd:string
