11-10-2011 11:05 PM - edited 03-13-2019 07:36 PM
Good Day All,
I am in the process of setting up directory handlers for Cisco Unity connection.
When I dial the extension for the directory handler ; I hear the default Cisco Unity connection greeting instead of being prompted for the search.
Can anyone shed any light on why this is happening?
Any help is greatly appreciated.
Thanks very much
Amanda
Solved! Go to Solution.
11-11-2011 06:45 AM
Are you sure you configured the routing in CUC correctly??
Exactly how are you reaching that directory handler?
java
If this helps, please rate
www.cisco.com/go/pdihelpdesk
11-11-2011 06:45 AM
java
11-14-2011 01:10 AM
Hi javalenc,
Of course , that was right. I worked it out in the end.
I was trying to copy the configuration from an older version of CUC and basically added an un-needed call forwarding rule under the Directory Handler. As soon as I removed it; the directory worked normally.
The other thing I learned last weekend was that the order of the routing rules is important.
My directory had the first priority and it was causing people who wanted to leave a voicemail for other users to get the prompts for the directory.
Thanks so much for the help though.
Amanda Lalli-Cafini
