Using Nortel VPN Client with IP Communicator
Jason Aarons
Level 6
Level 6
Can you reply if you have had success with Nortel VPN Client and IP Communicator. I'm getting one-way audio and think it might be a NAT/Routing issue, but want to rule the Nortel client out.
lisa.hall
Level 2
Level 2
Change the Network Audio settings to use the MAC Address instead of IP and even run a tracert from both the ends and see if they are using the same route.
This URL should help you:
http://www.cisco.com/en/US/customer/products/sw/voicesw/ps1860/products_tech_note09186a0080094ed1.shtml
How to Use Cisco IP SoftPhone over VPN:
http://www.cisco.com/warp/public/788/AVVID/sp_vpn.html
I'm using IP Communicator, I tired Preferences> Audio > Network > Audio IP Address > Use this Address and input my VPN ip address from ipconfig, then I ran a Ethereal Sniffer trace and I see UDP packets sourced from Nortel VPN Driver IP address to my H323 gateway. I then did a debug ip packet and see tcp packets arriving at the H323 gateway (SCCP i presume) but I never get any UDP packets that I saw in Ethereal.
