01-16-2006 10:46 PM - edited 03-15-2019 04:00 AM
Im tring to understand if vg248 supports t.38 for fax. The only document that describes vg248 mentions only cisco fax-relay, but from some discussions I see people talk of t.38. So does it support t.38?
And another question - if I have a vg248 and connect an analog phone to it and then I choose to use a modem or fax- do i need to reconfigure the port or it will work without the need to reconfigure it every time I change the connected equipment?
01-17-2006 02:08 AM
Enabling T.38 Fax Relay http://www.cisco.mn/en/US/products/hw/gatecont/ps2250/products_configuration_guide_chapter09186a0080235150.html#wp1038128
"To use T.38 fax relay on the VG248, follow the steps in the procedure below...."
01-17-2006 04:04 AM
and if I have non cisco gateway? nse force doesn`t look wery promising.
