VOIP Bandwidth problem
goku-sun
Hi all,
I have questions for you VOIP experts...
Are there much issues for a point-to-point VOIP service between 2 locations if ping delay between 2 ends is as large as 580ms (Routers=cisco 1750, meduium is Satellite)
Suscribed bandwidth is 128k but the voice quality is poor and often only one side can hear but the other can't.
TIA,
Goku
In my experience, VoIP doesn't work well on anything more than about 180ms of latency. 580ms is way beyond the recommendations from Cisco. Most wireless technologies, especially satelite, introduce too much latency to work well for VoIP, which is why Cisco won't currently support them. They also suck for games. :-)
As far as bandwidth is concerned, as long as you use QoS and do your calculations correctly (to determine the number of concurrent phone calls), quality is great.
jwang
580ms is Okay. but 128K is too low for calls without cRTP. if it's p-to-p link and serial interface on router, you should use compressed RTP and probably G.723.
carlos
You really need QoS for this setup. I´ve done it with a 64Kbps satellite link. Ping response is 600ms average. Got two simultaneous voice channels working with acceptable quality.
The only issue is the call setup, it takes about 10 seconds to establish the call. Oh.. and data will suffer because of the low MTU.
Here´s the relevant configuration
SITE A
Cisco 1750 2 FXO ports connected to a NEC PBX.
interface Serial0
description Enlace a Laredo
bandwidth 64
ip address 10.1.1.1 255.255.255.252
ip mtu 150
encapsulation ppp
ip tcp header-compression iphc-format
no keepalive
fair-queue 64 16 2
traffic-shape rate 64000 8000 8000 1000
ip rtp header-compression iphc-format
ip rsvp bandwidth 48 24
voice-port 1/0
timeouts ringing 20
timeouts wait-release 3
connection plar opx 200
codec g729r8
voice-port 1/1
timeouts ringing 20
connection plar opx 201
codec g729r8
dial-peer voice 101 pots
destination-pattern 5
port 1/0
dial-peer voice 102 pots
port 1/1
dial-peer voice 301 voip
destination-pattern 20.
session target ipv4:10.1.1.2
dtmf-relay h245-alphanumeric
req-qos controlled-load
SITE B
CISCO 1750 2 FXS ports with ordinary phones attached.
interface Serial0
description Enlace a Cd. de Mexico
bandwidth 64
ip address 10.1.1.2 255.255.255.252
ip mtu 150
encapsulation ppp
no keepalive
fair-queue 64 16 2
voice-port 1/0
voice-port 1/1
destination-pattern 200
port 1/0
destination-pattern 201
port 1/1
session target ipv4:10.1.1.1
Hope this helps.
Carlos
Many thks Carlos,
I indeed appreciate your experience sharing.. May I ask if the access routers connecting your 1750's need any special qos config? Are those commands also involve compression apart of BW reservation?
My existing config uses frame-relay dividing the serail into 2 PVC's(one for voice and the other for "intranet") by traffic shaping commands. I tried to dedicate the whole 128k BW for voice but still one of the conversation(only one voice call active) will die after a miniute or so. Therefore I am right in guessing there may be other issues around..
cheers,
Goku
